[postgis-tickets] [PostGIS] #2485: [raster]: raster constraints prevent raster data from restoring
trac at osgeo.org
Tue Sep 24 07:45:01 PDT 2013
Reporter: rdunklau | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.5
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
You can safely use the "sed" approach if the database (dumped) is well
organized, even with custom user functions. Basically, as long as PostGIS
is installed in its own schema and you keep it that way (not add stuff not
part of PostGIS to that schema), you can safely make changes to the SET
search_path.
If you've got more complicated situations (messy), you'll need something
more fancy. I unfortunately don't have those scripts anymore (changed
jobs) but I used the utils/create_undef.pl script as a reference point.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:18>
