[postgis-tickets] [PostGIS] #2396: liblwgeom CUnit and PostgreSQL tests fail on big-endian architectures.
PostGIS trac at osgeo.org
Thu Sep 26 20:32:16 PDT 2013
  Reporter:  mnencia  |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.1.1
 Component:  postgis  |     Version:  2.1.x
Resolution:           |    Keywords:
Comment(by robe):
 I've patched the #690 mips/sparc tickets.sql failure for 2.1 at r11983
 #2048 as far as I can tell is not an endian issue.  Those are geos checks
 which I would expect to resolve the same regardless the endian input of
 the geometries.  Which version of GEOS are you running on armel and armhf?
 -#2048|1|f|f
 +#2048|1|f|t
  #2048|2|t|t
 -#2048|3|f|f
 +#2048|3|f|t
 The mipsel failure
 make: *** [check] Error 1
 -4|0|1
 -Topology 'tt3d' dropped
 +psql: FATAL:  the database system is in recovery mode
 Looks like a GEOS bug too which crashed your PostGIS instance -- let us
 know what version of GEOS you are running.  It may be patched in a newer
 GEOS or a bug in GEOS yet to be patched.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2396#comment:30>
