[postgis-tickets] [PostGIS] #2396: liblwgeom CUnit and PostgreSQL tests fail on big-endian architectures.
PostGIS trac at osgeo.org
Fri Sep 27 04:02:12 PDT 2013
  Reporter:  mnencia  |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.1.1
 Component:  postgis  |     Version:  2.1.x
Resolution:           |    Keywords:
Comment(by robe):
 I did see a transposition incosistency but I reversed it the wrong way.
 This failing ticket should really refer to ticket #2084 so I'll have to
 fix that.
 The sfcgal tickets.sql still needs to be fixed too but I'm not setup to
 test sfcgal so I am hesitant to change that.  I'll put that one as a
 separate ticket to patch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2396#comment:31>
