[postgis-tickets] [PostGIS] #2440: Remove warnings from functions deprecated in 2.1.0
trac at osgeo.org
Fri Sep 27 08:08:20 PDT 2013
Reporter: realityexists | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.1.1
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
Comment:
I think this change shouldn't been made. The old signature is gone, you
shouldn't use it.
If you tried using a deprecated signature in raster you'd get an ERROR. A
WARNING is a courtesy we do to the user. If it annoys you, change your
code to use the correct signature.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2440#comment:5>
