[postgis-tickets] [PostGIS] #2869: St_Centroid doesn't work on curved geom
PostGIS trac at osgeo.org
Fri Aug 1 07:49:03 PDT 2014
 Reporter:  remic        |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
Comment(by remic):
 Here is a wrapper ,
 totally non optimal
 DROP FUNCTION IF EXISTS public.rc_centroid(  igeom GEOMETRY);
 CREATE OR REPLACE FUNCTION public.rc_centroid(
         igeom GEOMETRY
         )  RETURNS GEOMETRY AS
 $BODY$
         -- at brief : this function is a thin wrapper around st_centroid than
 enable to use it with circularstring
         -- at param : a geom whose centroid we want
         -- at return : teh centroid
                 DECLARE
                 BEGIN
                         --RAISE EXCEPTION 'hello,  % , %',
 st_astext(igeom), st_geometrytype(igeom) ;
                         IF ST_GeometryType(igeom) ILIKE '%CircularString%'
                         THEN
                                 --special case, we cast the circularstring
 to multipoint
                                 RETURN ST_Centroid(ST_Collect(dmp.geom))
                                 FROM ST_DumpPoints(igeom) as dmp
                                 WHERE dmp.path =ARRAY[1] OR dmp.path
 =ARRAY[3];
                         END IF ; --cicular string
                         RETURN ST_Centroid(igeom) ;
                 END ;
         --test
         --SELECT ST_AsText(rc_centroid(geom ))
         --FROM st_geomfromtext('circularstring(0 0 , 1 1, 2 0)') as geom ;
 $BODY$
  LANGUAGE plpgsql IMMUTABLE STRICT;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2869#comment:2>
