[postgis-tickets] [PostGIS] #2870: Binary insert into geography column results in value being inserted as geometry.
trac at osgeo.org
Sun Aug 3 00:54:55 PDT 2014
geometry.
Reporter: andrewdone | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by andrewdone):
Replying to [comment:2 pramsey]:
> You're seeing an error in the metadata, everything about the object
should still be OK, so your library is going to be OK. I will fix the bug
though.
Hi Paul,
It actually doesn't work correctly; if you can run that Java file you'll
see that ID:2 (not geography) doesn't work as expected with the majority
of spatial filters (st_dwithin, st_covers, st_coversby, etc). The
st_summary case I presented was all I could come up with to try and
ascertain that something was different about them.
I tried to dig into the postgis code to see what was actually different
about them, but wasn't able to make good headway there. Sorry.
I'm pushing the library I'm building to just use WKT and rely on the
canonical translation to geography for now -- which works fine -- but, to
confirm, if I used binary transfer in the manner isolated above, the only
thing that seemed to work was st_distance. In most cases, it wasn't a case
of getting erroneous results back, it simply wouldn't get any results back
at all.
So, yeah, my immediate problem is sorted but I'm more than happy to help
in any way I can if you want to get to the bottom of it (and it'd be great
to be able to use WKB).
Cheers,
- AD.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2870#comment:3>
