[postgis-tickets] [PostGIS] #2870: Binary insert into geography column results in value being inserted as geometry.
PostGIS trac at osgeo.org
Wed Aug 6 07:13:34 PDT 2014
geometry.
 Reporter:  andrewdone  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.1.4
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
Comment(by pramsey):
 Jeebus, why does that even work? So you turn it into a bytea and then
 somehow it morphs into a geometry and finds a code path that avoids even
 the typmod check...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2870#comment:9>
