[postgis-tickets] [PostGIS] #2872: make install builds documentation
PostGIS trac at osgeo.org
Wed Aug 6 15:47:28 PDT 2014
 Reporter:  gdt                    |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.4
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Changes (by gdt):
  * version:  2.0.x => 2.1.x
Comment:
 Also, the topology extension creates files during install:
 for OLD_VERSION in 2.0.0 2.0.1 2.0.2 2.0.3 2.0.4 2.0.5 2.1.0rc1 2.1.0rc2
 2.1.0rc3 2.1.0 2.1.1 2.1.2; do \
           cat ../postgis_extension_helper.sql
 sql_bits/remove_from_extension.sql.in sql/topology_upgrade_minor.sql
 sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql
 ../postgis_extension_helper_uninstall.sql >
 sql/postgis_topology--$OLD_VERSION--2.1.3.sql; \
 done
 This happens for "gmake all", which is fine, but again for "gmake
 install".  Confirmed with 2.1.3, NetBSD 6 i386, postgresql 9.1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2872#comment:2>
