[postgis-tickets] [PostGIS] #2872: make install builds documentation
PostGIS trac at osgeo.org
Thu Aug 7 00:54:22 PDT 2014
 Reporter:  gdt                    |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.4
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 Can you check with --disable-extension ?
 I belive the problem is with extension requiring comments which require
 DocBook and is thus not built at "make" time, or something like that.
 The correct solution would be to always build docs at "make" time if deps
 are met, or warn and disable extension if deps are not met.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2872#comment:3>
