[postgis-tickets] [PostGIS] #2872: make install builds documentation
PostGIS trac at osgeo.org
Thu Aug 7 04:39:21 PDT 2014
 Reporter:  gdt                    |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.4
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by gdt):
 --disable-extension is unrecogized.   With --without-topology --without-
 raster, I find that the xsltproc are unchanged, but the comment:2 for/cat
 loop is no longer present.
 Apparently with pkgsrc moving to 2.1.3 there is now also
 /usr/pkg/bin/xsltproc --novalid ./xsl/sfcgal_comments.sql.xsl postgis-
 out.xml > sfcgal_comments.sql
 It's a bit hard to follow the makefiles, but it seems the top-level
 makefile install target invokes comments-install, so the xsltproc doesn't
 seem to be about extensions, which matches what I'm seeing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2872#comment:4>
