[postgis-tickets] [PostGIS] #2872: make install builds documentation
PostGIS trac at osgeo.org
Thu Aug 7 04:46:15 PDT 2014
 Reporter:  gdt                    |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.4
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 Still, if you only run "make" and "make install" from within the doc/
 subdir there should be no influence from the extension mechanism.
 Ideally "make install" from doc/ dir should not build anything new from
 "make" within the same dir.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2872#comment:7>
