[postgis-tickets] [PostGIS] #2878: winnie coughing up blood when trying to build cunit for twkb
trac at osgeo.org
Thu Aug 7 14:28:41 PDT 2014
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
It started today I think after r12867
Debbie seems to be fine with the changes.
libtool: link: x86_64-w64-mingw32-gcc -g -O2 -Wall -Wmissing-prototypes
-I/projects/geos/rel-3.5.0devw64gcc48/include
-I/projects/proj/rel-4.8.0w64gcc48/include
-I/projects/postgresql/rel/pg9.4w64gcc48/include -I/projects/rel-
libiconv-1.13.1w64gcc48/include -I.. -I/projects/CGAL/rel-
sfcgal-1.0.4w64gcc48/include -DHAVE_SFCGAL -o .libs/cu_tester
cu_algorithm.o cu_buildarea.o cu_clean.o cu_print.o cu_misc.o cu_ptarray.o
cu_geodetic.o cu_geos.o cu_tree.o cu_measures.o cu_node.o cu_libgeom.o
cu_split.o cu_stringbuffer.o cu_triangulate.o cu_homogenize.o
cu_force_sfs.o cu_out_twkb.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_out_encoded_polyline.o
cu_surface.o cu_out_x3d.o cu_in_geojson.o cu_in_wkb.o cu_in_wkt.o
cu_in_encoded_polyline.o cu_varint.o cu_tester.o cu_sfcgal.o
../.libs/liblwgeom.a -L/projects/postgresql/rel/pg9.4w64gcc48/lib
-L/projects/gdal/rel-1.11.0w64gcc48/lib -L/projects/rel-
libiconv-1.13.1w64gcc48/lib -L/projects/geos/rel-3.5.0devw64gcc48/lib
-L/projects/proj/rel-4.8.0w64gcc48/lib
-L/projects/json-c/rel-0.12w64gcc48/lib -L/projects/CGAL/rel-
sfcgal-1.0.4w64gcc48/lib
/projects/proj/rel-4.8.0w64gcc48/lib/libproj.dll.a
/projects/json-c/rel-0.12w64gcc48/lib/libjson-c.a -lgeos_c
/mingw/x86_64-w64-mingw32/lib/libcunit.a
-L/projects/CUnit-2.1-2/CUnit/Sources /projects/CGAL/rel-
sfcgal-1.0.4w64gcc48/lib/libSFCGAL.dll
-L/projects/proj/rel-4.8.0w64gcc48/lib -L/projects/CGAL/rel-
../.libs/liblwgeom.a(lwout_twkb.o): In function `varint_u32_encoded_size':
e:\jenkins\postgis\branches\2.2\liblwgeom/varint.h:63: multiple definition
of `varint_u32_encoded_size'
cu_varint.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/../varint.h:63:
first defined here
../.libs/liblwgeom.a(lwout_twkb.o): In function `varint_u32_encode_buf':
e:\jenkins\postgis\branches\2.2\liblwgeom/varint.h:78: multiple definition
of `varint_u32_encode_buf'
cu_varint.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/../varint.h:78:
first defined here
../.libs/liblwgeom.a(lwout_twkb.o): In function `varint_s32_encoded_size':
e:\jenkins\postgis\branches\2.2\liblwgeom/varint.h:83: multiple definition
of `varint_s32_encoded_size'
cu_varint.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/../varint.h:83:
first defined here
../.libs/liblwgeom.a(lwout_twkb.o): In function `varint_s32_encode_buf':
e:\jenkins\postgis\branches\2.2\liblwgeom/varint.h:99: multiple definition
of `varint_s32_encode_buf'
cu_varint.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/../varint.h:99:
first defined here
../.libs/liblwgeom.a(lwout_twkb.o): In function `varint_s64_encoded_size':
e:\jenkins\postgis\branches\2.2\liblwgeom/varint.h:105: multiple
definition of `varint_s64_encoded_size'
cu_varint.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/../varint.h:105:
first defined here
../.libs/liblwgeom.a(lwout_twkb.o): In function `varint_s64_encode_buf':
e:\jenkins\postgis\branches\2.2\liblwgeom/varint.h:122: multiple
definition of `varint_s64_encode_buf'
cu_varint.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/../varint.h:122:
first defined here
../.libs/liblwgeom.a(lwout_twkb.o): In function `varint_u64_encoded_size':
e:\jenkins\postgis\branches\2.2\liblwgeom/varint.h:128: multiple
definition of `varint_u64_encoded_size'
cu_varint.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/../varint.h:128:
first defined here
../.libs/liblwgeom.a(lwout_twkb.o): In function `varint_u64_encode_buf':
e:\jenkins\postgis\branches\2.2\liblwgeom/varint.h:143: multiple
definition of `varint_u64_encode_buf'
cu_varint.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/../varint.h:143:
first defined here
../.libs/liblwgeom.a(lwout_twkb.o):lwout_twkb.c:(.rdata+0x2f4): multiple
definition of `varint_s32_max'
cu_varint.o:cu_varint.c:(.rdata+0x1e0): first defined here
../.libs/liblwgeom.a(lwout_twkb.o):lwout_twkb.c:(.rdata+0x2f8): multiple
definition of `varint_s32_min'
cu_varint.o:cu_varint.c:(.rdata+0x1e4): first defined here
../.libs/liblwgeom.a(lwout_twkb.o):lwout_twkb.c:(.rdata+0x2fc): multiple
definition of `varint_u32_max'
cu_varint.o:cu_varint.c:(.rdata+0x1e8): first defined here
../.libs/liblwgeom.a(lwout_twkb.o):lwout_twkb.c:(.rdata+0x300): multiple
definition of `varint_s64_max'
cu_varint.o:cu_varint.c:(.rdata+0x1f0): first defined here
../.libs/liblwgeom.a(lwout_twkb.o):lwout_twkb.c:(.rdata+0x308): multiple
definition of `varint_s64_min'
cu_varint.o:cu_varint.c:(.rdata+0x1f8): first defined here
../.libs/liblwgeom.a(lwout_twkb.o):lwout_twkb.c:(.rdata+0x310): multiple
definition of `varint_u64_max'
cu_varint.o:cu_varint.c:(.rdata+0x200): first defined here
../.libs/liblwgeom.a(lwout_wkb.o): In function `hexbytes_from_bytes':
e:\jenkins\postgis\branches\2.2\liblwgeom/lwout_wkb.c:24: multiple
definition of `hexbytes_from_bytes'
cu_out_twkb.o:e:\jenkins\postgis\branches\2.2\liblwgeom\cunit/cu_out_twkb.c:54:
first defined here
collect2.exe: error: ld returned 1 exit status
Makefile:83: recipe for target `cu_tester' failed
make[2]: *** [cu_tester] Error 1
make[2]: Leaving directory
`/projects/postgis/branches/2.2/liblwgeom/cunit'
Makefile:156: recipe for target `check' failed
make[1]: *** [check] Error 2
make[1]: Leaving directory `/projects/postgis/branches/2.2/liblwgeom'
GNUmakefile:14: recipe for target `check' failed
make: *** [check] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2878>
