[postgis-tickets] [PostGIS] #2880: cu_varint warnings
trac at osgeo.org
Thu Aug 7 16:52:21 PDT 2014
Reporter: robe | Owner: nicklas
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
cu_varint.c
cu_varint.c: In function 'do_test_u32_varint':
cu_varint.c:30:2: warning: implicit declaration of function
'varint_u32_encoded_size' [-Wimplicit-function-declaration]
size = varint_u32_encoded_size(nr);
cu_varint.c:35:2: warning: implicit declaration of function
'varint_u32_encode_buf' [-Wimplicit-function-declaration]
varint_u32_encode_buf(nr, buf);
cu_varint.c: In function 'do_test_s32_varint':
cu_varint.c:50:2: warning: implicit declaration of function
'varint_s32_encoded_size' [-Wimplicit-function-declaration]
size = varint_s32_encoded_size(nr);
cu_varint.c:55:2: warning: implicit declaration of function
'varint_s32_encode_buf' [-Wimplicit-function-declaration]
varint_s32_encode_buf(nr, buf);
cu_varint.c: In function 'do_test_u64_varint':
cu_varint.c:70:2: warning: implicit declaration of function
'varint_u64_encoded_size' [-Wimplicit-function-declaration]
size = varint_u64_encoded_size(nr);
cu_varint.c:75:2: warning: implicit declaration of function
'varint_u64_encode_buf' [-Wimplicit-function-declaration]
varint_u64_encode_buf(nr, buf);
cu_varint.c: In function 'do_test_s64_varint':
cu_varint.c:90:2: warning: implicit declaration of function
'varint_s64_encoded_size' [-Wimplicit-function-declaration]
size = varint_s64_encoded_size(nr);
cu_varint.c:95:2: warning: implicit declaration of function
'varint_s64_encode_buf' [-Wimplicit-function-declaration]
varint_s64_encode_buf(nr, buf);
cu_varint.c: In function 'test_varint':
cu_varint.c:154:2: warning: this decimal constant is unsigned only in ISO
C90 [enabled by default]
do_test_s32_varint(-2147483648, 5, "FFFFFFFF0F");
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2880>
