[postgis-tickets] [PostGIS] #2880: cu_varint warnings
trac at osgeo.org
Thu Aug 7 16:57:16 PDT 2014
Reporter: robe | Owner: nicklas
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
before the change r12871 I made to get rid of varint.h
used to give these warnings:
In file included from cu_varint.c:23:0:
../varint.h:62:1: warning: no previous prototype for
'varint_u32_encoded_size' [-Wmissing-prototypes]
varint_u32_encoded_size(uint32_t val)
../varint.h:75:1: warning: no previous prototype for
'varint_u32_encode_buf' [-Wmissing-prototypes]
varint_u32_encode_buf(uint32_t val, uint8_t *buf)
../varint.h:82:1: warning: no previous prototype for
'varint_s32_encoded_size' [-Wmissing-prototypes]
varint_s32_encoded_size(int32_t val)
../varint.h:96:1: warning: no previous prototype for
'varint_s32_encode_buf' [-Wmissing-prototypes]
varint_s32_encode_buf(int32_t val, uint8_t *buf)
../varint.h:104:1: warning: no previous prototype for
'varint_s64_encoded_size' [-Wmissing-prototypes]
varint_s64_encoded_size(int64_t val)
../varint.h:118:1: warning: no previous prototype for
'varint_s64_encode_buf' [-Wmissing-prototypes]
varint_s64_encode_buf(int64_t val, uint8_t *buf)
../varint.h:127:1: warning: no previous prototype for
'varint_u64_encoded_size' [-Wmissing-prototypes]
varint_u64_encoded_size(uint64_t val)
../varint.h:140:1: warning: no previous prototype for
'varint_u64_encode_buf' [-Wmissing-prototypes]
varint_u64_encode_buf(uint64_t val, uint8_t *buf)
cu_varint.c: In function 'test_varint':
cu_varint.c:156:2: warning: this decimal constant is unsigned only in ISO
C90 [enabled by default]
do_test_s32_varint(-2147483648, 5, "FFFFFFFF0F");
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2880#comment:1>
