[postgis-tickets] [PostGIS] #2878: winnie coughing up blood when trying to build cunit for twkb
trac at osgeo.org
Sun Aug 10 17:04:46 PDT 2014
Reporter: robe | Owner: nicklas
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment(by robe):
Did a compare of the 2 on my
PostgreSQL 9.4beta2, compiled by Visual C++ build 1800, 32-bit
Here are my results
-- 2 part means varint.h, varint.c (from r12836)
-- single means varint.h as single file with funcs (from circa r12875)
-- 2 part runs: 5231 ms (fresh restart), 5121ms (fresh restart), 5663 ms
(fresh start),
-- 5616ms (fresh start), 4602 ms (warm), 4881ms (warm), 4634ms
(warm), 4899ms (warm)
-- single runs: 4991 ms (fresh start), 4649 ms (fresh start), 5554 ms
(fresh start), 5523ms (fresh start),
-- 5600 ms (warm), 5507 ms (warm), 4555ms (warm), 4540 ms (warm),
4524 ms (warm)
DROP TABLE IF EXISTS c;
create table c as
select st_astwkb(geom, 0) from a;
and as you said in both cases the explain analyze is consistently the same
-- single run: execution time (2589.146 ms, plan 1.571ms) (start),
execution time (2574.146 ms, plan 0.056ms) (warm),
-- execution time (2623ms, plan 0.049) (warm), execution time
(2555.248ms, plan 0.049) (warm),
-- 2 part: execution time (2580.143ms, plan 1.093ms) (start), execution
time (2612ms, plan 0.049) (warm), execution time (2591.289ms, plan 0.049)
(warm)
explain (analyze)
So even though the create table does seem on average faster with having a
single file, there is so much noise (particularly with the single) coming
from somewhere I really can't tell since some runs are actually slower
than the 2 file.
I would say if we have a problem, then as you said it probably affects
every output function we have. Might as well just ere on the safe side
and break varint back up and put in a separate ticket to investigate this
issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2878#comment:19>
