[postgis-tickets] [PostGIS] #2878: winnie coughing up blood when trying to build cunit for twkb
trac at osgeo.org
Sun Aug 10 20:53:47 PDT 2014
Reporter: robe | Owner: nicklas
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment(by nicklas):
No, no cassert. No options at all.
I forget to write I only tested it warm. I left out the first run after
restarting.
As I wrote I earlier found that moving the functions to the header file
gave almost the same result as having everything in lwout_twkb.c but in
the tests above I test "all i lwout_twkb.c" vs "splitted in lwout_twkb.c
and varint.c with header varint.h". I feel more sure about this difference
than between r12836 and all varibt functions i varint.h
I will be away till tusdat evening but I think I will try to comit the
r12836 state of those files today.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2878#comment:20>
