[postgis-tickets] [PostGIS] #2878: winnie coughing up blood when trying to build cunit for twkb
PostGIS trac at osgeo.org
Sun Aug 10 21:55:25 PDT 2014
  Reporter:  robe     |       Owner:  nicklas
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment(by nicklas):
 Back to version with varint functions in varint.c with definitions in
 varint.h in r12883.
 I will try later this week to investigate the performande issue discussed
 above and open a new ticket.
 First priority is to find out if this happens also when the result is read
 from a client. If so, this is worth investigating.
 When testing twkb and comparing results with ST_AsBinary I have seen some
 strange results with ST_AsBinary performing bad. I think this might be the
 same issue. And reading with ST_AsBinary from a client I guess is the most
 common usage of PostGIS in all categories (QGIS, Mapnik MapServer and so
 on)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2878#comment:21>
