[postgis-tickets] [PostGIS] #2892: cunit for cu_varint warnings
trac at osgeo.org
Sun Aug 10 22:33:08 PDT 2014
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
These show on winnie after r12883 commit. Haven't checked debbie. I
think these ones are my fault :( since I had taken out the
hexbytes_from_bytes def in cu_varint.c at r12871 because I saw it already
defined.
cu_varint.c:34:2: warning: implicit declaration of function
'hexbytes_from_bytes' [-Wimplicit-function-declaration]
hex = hexbytes_from_bytes(buf,size);
cu_varint.c:34:6: warning: assignment makes pointer from integer without a
cast [enabled by default]
cu_varint.c:39:3: warning: implicit declaration of function 'lwfree'
lwfree(hex);
cu_varint.c: In function 'do_test_s32_varint':
cu_varint.c:54:6: warning: assignment makes pointer from integer without a
cu_varint.c: In function 'do_test_u64_varint':
cu_varint.c:74:6: warning: assignment makes pointer from integer without a
cu_varint.c: In function 'do_test_s64_varint':
cu_varint.c:94:6: warning: assignment makes pointer from integer without a
cu_varint.c: In function 'test_varint':
cu_varint.c:152:2: warning: this decimal constant is unsigned only in ISO
C90 [enabled by default]
do_test_s32_varint(-2147483648, 5, "FFFFFFFF0F");
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2892>
