[postgis-tickets] [PostGIS] #2898: Define a guideline for function cost
trac at osgeo.org
Fri Aug 15 08:01:09 PDT 2014
Reporter: strk | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Example guideline for rasters:
-- COST assignment guideline (TODO):
-- By default C functions get assigned a cost of 1 while (plpg)sql
functions
-- get assigned a cost of 100. Value expressed in "cpu_operator_cost"
units.
-- See http://www.postgresql.org/docs/9.1/static/runtime-config-query.html
#GUC-CPU-OPERATOR-COST
-- The following schema can be used as a guideline to set cost of each
-- function. The multiplier would apply to the language based default
-- (1 or 100) and to the number of raster arguments.
-- For example a multiplier of 500 for a C function taking 2 rasters
-- and performing operations on each of their pixel would have a cost
-- of 1000.
-- o Only detoast raster header
-- x 1
-- o Detoast whole raster
-- x 100
-- o Scan each raster pixel
-- x 300
-- o Perform operations on each raster pixel
-- x 500
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2898#comment:1>
