[postgis-tickets] [PostGIS] #2897: winnie testing crashes on raster tests
PostGIS trac at osgeo.org
Fri Aug 15 21:33:28 PDT 2014
  Reporter:  robe       |       Owner:  robe
      Type:  defect     |      Status:  closed
  Priority:  blocker    |   Milestone:  PostGIS 2.1.4
 Component:  buildbots  |     Version:  trunk
Resolution:  fixed      |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I still have the issue with its building with GDAL 1.10.0 (not sure where
 it's getting that from).  However I discovered I had accidentally polluted
 my postgresql bin folder with libgdal1.dll (from 1.9.2), so it was picking
 that up but the code was compiled with 1.10.0 which I think was what was
 causing the crashing.  Once I deleted that file and the gdal-data folder I
 had also accidentally copied, it started passing regression again.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2897#comment:1>
