[postgis-tickets] [PostGIS] #2897: winnie testing crashes on raster tests
PostGIS trac at osgeo.org
Fri Aug 15 07:05:21 PDT 2014
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  blocker    |   Milestone:  PostGIS 2.1.4
Component:  buildbots  |     Version:  trunk
 Keywords:             |
 I've been ignoring this for a bit, but on winnie buildbot testing if I'm
 getting crashers on 9.2.  Might be just bot specific since I was in middle
 of setting this extensions.
 Issue doesn't exists in 2.2 which is compiling (and regressing) with GDAL
 1.11.0.
 This might be an incompatibility with GDAL I am compiling with.  Seems its
 testing against 1.9 but compiling against 1.10.0 so have to figure out why
 that is. So might only happen if you compile with a different version of
 GDAL than what you are running with or a bug in GDAL 1.9
 GEOS config:          /projects/geos/rel-3.4.2w64/bin/geos-config
   GEOS version:         3.4.2
   GDAL config:          /projects/gdal/rel-1.10.0w64/bin/gdal-config
   GDAL version:         1.10.0
   PostgreSQL config:    /projects/postgresql/rel/pg9.2w64/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.2.4
   PROJ4 version:        48
   Libxml2 config:       /projects/libxml/rel-
 libxml2-2.7.8w64/bin/xml2-config
   Libxml2 version:      2.7.8
   JSON-C support:       yes
   PostGIS debug level:  0
   Perl:                 /bin/perl
 PostgreSQL 9.2.4 on x86_64-w64-mingw32, compiled by gcc.exe (GCC) 4.5.4
 20111030 (prerelease) [svn/rev.180676 - mingw-w64/oz], 64-bit
   Postgis 2.1.4dev
  - r12886
  - 2014-08-15 00:10:22
   scripts 2.1.4dev r12886
   raster scripts 2.1.4dev r12886
   GEOS: 3.4.2-CAPI-1.8.2 r0
   PROJ: Rel. 4.8.0, 6 March 2012
   GDAL: GDAL 1.9.1, released 2012/05/15
 Running tests
  check_gdal .. ok
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  box3d .. ok
  rt_addband .. ok
  rt_band .. ok
  rt_tile .. ok
  rt_dimensions .. ok
  rt_scale .. ok
  rt_pixelsize .. ok
  rt_upperleft .. ok
  rt_rotation .. ok
  rt_georeference .. ok
  rt_set_properties .. ok
  rt_isempty .. ok
  rt_hasnoband .. ok
  rt_metadata .. ok
  rt_rastertoworldcoord .. ok
  rt_worldtorastercoord .. ok
  rt_convexhull .. ok
  rt_band_properties .. ok
  rt_set_band_properties .. ok
  rt_pixelaspolygons .. ok
  rt_pixelaspoints .. ok
  rt_pixelascentroids .. ok
  rt_setvalues_array .. ok
  rt_summarystats .. ok
  rt_count .. ok
  rt_histogram .. ok
  rt_quantile .. ok
  rt_valuecount .. ok
  rt_valuepercent .. ok
  rt_bandmetadata .. ok
  rt_pixelvalue .. ok
  rt_neighborhood .. ok
  rt_nearestvalue .. ok
  rt_pixelofvalue .. ok
  rt_polygon .. ok
  rt_utility .. ok
  rt_reclass .. ok
  rt_gdalwarp .. ok
  rt_asraster .. ok
  rt_dumpvalues .. ok
  rt_mapalgebraexpr .. ok
  rt_mapalgebrafct .. ok
  rt_mapalgebraexpr_2raster .. ok
  rt_mapalgebrafct_2raster .. ok
  rt_mapalgebrafctngb .. ok
  rt_mapalgebrafctngb_userfunc .. ok
  rt_intersection .. ok
  rt_clip .. ok
  rt_mapalgebra .. ok
  rt_mapalgebra_expr .. ok
  rt_union .. ok
  rt_invdistweight4ma .. ok
  rt_4ma .. ok
  rt_setvalues_geomval .. ok
  rt_elevation_functions .. ok
  rt_colormap .. ok
  rt_gist_relationships .. ok
  rt_intersects .. ok
  rt_samealignment .. ok
  rt_geos_relationships .. ok
  rt_iscoveragetile .. ok
  bug_test_car5 .. ok
  permitted_gdal_drivers .. failed (diff expected obtained:
 /projects/postgis/tmp/2.1.4dev_pg9.2_geos3.4.2_gdal1.10.0w64/test_68_diff)
 --- permitted_gdal_drivers_expected     2014-05-04 12:24:55 -0400
 /projects/postgis/tmp/2.1.4dev_pg9.2_geos3.4.2_gdal1.10.0w64/test_68_out
 2014-08-14 20:20:31 -0400
 @@ -1,10 +1,6 @@
  DO
  4326
 -ERROR:  RASTER_fromGDALRaster: Could not open bytea with GDAL. Check that
 the bytea is of a GDAL supported format
 -ERROR:  rt_raster_load_offline_data: Access to offline bands disabled
 -4326
 -4326
 -4326
 +server closed the connection unexpectedly
 +       This probably means the server terminated abnormally
 +       before or while processing the request.
 +connection to server was lost
  tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.1.4dev_pg9.2_geos3.4.2_gdal1.10.0w64/test_69_diff)
 --- tickets_expected    2013-11-27 11:24:51 -0500
 /projects/postgis/tmp/2.1.4dev_pg9.2_geos3.4.2_gdal1.10.0w64/test_69_out
 @@ -1 +1 @@
 -#1485|0
 +psql: FATAL:  the database system is in recovery mode
  loader/Basic ... failed ( test: running raster2pgsql output:
 /projects/postgis/tmp/2.1.4dev_pg9.2_geos3.4.2_gdal1.10.0w64/loader.err)
  loader/BasicCopy .... ok
  loader/BasicFilename .... ok
  clean .. ok
  uninstall .  /projects/postgis/branches/2.1/regress/00-regress-
 install/share/contrib/postgis/uninstall_rtpostgis.sql
 install/share/contrib/postgis/uninstall_postgis.sql
 . ok (4061
 Run tests: 74
 Failed: 3
 make[3]: *** [check] Error 3
 make[3]: Leaving directory
 `/projects/postgis/branches/2.1/raster/test/regress'
 make[2]: *** [check] Error 2
 make[2]: Leaving directory `/projects/postgis/branches/2.1/raster/test'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/projects/postgis/branches/2.1/raster'
 make: *** [check] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2897>
