[postgis-tickets] [PostGIS] #2759: script postgis_restore.pl fails on some complexes comments
PostGIS trac at osgeo.org
Tue Aug 26 02:07:40 PDT 2014
 Reporter:  xcaeag                 |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.4
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 Do you have the dump around to test a different patch ?
 To be robust the patch should recognize COMMENT lines and find the correct
 end of the command
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2759#comment:5>
