[postgis-tickets] [PostGIS] #2911: ST_Rescale changes extent
trac at osgeo.org
Thu Aug 28 03:05:27 PDT 2014
Reporter: strk | Owner: strk
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.1.4
Component: raster | Version: 2.1.x
Keywords: |
Changes (by strk):
* owner: dustymugs => strk
* status: new => assigned
Comment:
I confirm the problem is with re-setting geotransform to the original one
as the last step of warping when the default geotransform was changed to
an arbitrary projection.
If a scale change was requested, the reset should take into account that
change.
This is likely to also affect rotation...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2911#comment:4>
