[postgis-tickets] [PostGIS] #2914: ST_Rescale: Could not create GDAL transformation object for output dataset creation
trac at osgeo.org
Fri Aug 29 07:17:35 PDT 2014
creation
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.4
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by strk):
Figured out, the problem is that the ST_Rescale call ends up calling
_st_gdalwarp passing NULL srs for both source and destination when they
are the same. The core then does not enter the special case of default
georeference, but doesn't have an SRS to initialize GDAL with either.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2914#comment:2>
