[postgis-tickets] [PostGIS] #2249: [raster] Implement ST_MakeEmptyCoverage
trac at osgeo.org
Fri Aug 29 11:09:23 PDT 2014
Reporter: dzwarg | Owner: dzwarg
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: raster |
Comment(by pracine):
Replying to [comment:5 strk]:
> I've taken a look at the function signature in the latest patch and got
a bit scared :)
> I imagine a coverage creation as two steps:
> 1. Creation of the table that would represent the coverage
configuration
> 2. Population of the coverage
> The first step could be similar to AddRasterColumn, that is it only
creates a structure,
> w/out inserting the data.
> The way I'd call such a coverage-creation function would be by passing
it:
> Mandatory:
> 1. The spatial extent to be covered by the coverage
> 2. The pixel size in geographical units (the scale)
> Optional:
> 3. SRID. Unconstrained if not given. [ok, maybe this could be
mandatory]
> 4. The max size of coverage tiles in pixels. Unconstrained if not
given.
> I see this function instead creates a whole set of empty tiles,
> which is possibly a big waste of time as you probably want to later
modify
> those tiles to have actual data in them...
> Also for a big coverage it could be very easy to end up out of memory.
ST_MakeEmptyCoverage() should create EMPTY rasters tiles, thus having no
bands and hence almost no data. It is useful for any query that want a set
of reference tiles to recreate a raster coverage from an existing one or
from a vector coverage (rasterizing). You use, for example, to create on
the fly an empty raster table in the FROM geomtable, (SELECT
ST_MakeEmptyCoverage() rast) that is used only as reference by function in
the SELECT. Many functions have a reference raster as parameter from which
they borrow alignment information.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2249#comment:8>
