[postgis-tickets] [PostGIS] #3005: Numeric overflow when executing AddRasterConstraints
trac at osgeo.org
Mon Dec 1 08:46:50 PST 2014
Reporter: rtorre | Owner: dustymugs
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.5
Component: raster | Version: 2.1.x
Keywords: |
We are experiencing a `numeric field overflow` when adding overviews to a
raster and subsequently calling `AddRasterConstraints`.
Executing this:
SELECT
AddRasterConstraints('cdb_importer','o_256_importer_e7efb068796911e4a19a5e0004719e63','the_raster_webmercator',TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,FALSE,TRUE,TRUE,TRUE,TRUE,TRUE);
I get this in the postgresql log:
PL/pgSQL function
addrasterconstraints(name,name,name,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean)
line 53 at RETURN
psql:/tmp/imports/20141201-2293-x4pho4/importer_e7efb068796911e4a19a5e0004719e63.sql:7472:
NOTICE: SQL used for failed constraint: ALTER TABLE
cdb_importer.o_256_importer_e7efb068796911e4a19a5e0004719e63 ADD
CONSTRAINT enforce_sca
lex_the_raster_webmercator CHECK
(st_scalex(the_raster_webmercator)::numeric(16,10) =
(1252219.04682188)::numeric(16,10))
CONTEXT: PL/pgSQL function
_add_raster_constraint_scale(name,name,name,character) line 38 at RETURN
PL/pgSQL function addrasterconstraints(name,name,name,text[]) line
60 at assignment
PL/pgSQL function
line 53 at RETURN
NOTICE: Returned error message: numeric field overflow
I think the problem is located in the file
`./raster/rt_pg/rtpostgis.sql.in`, around lines 6964-6968:
sql := 'ALTER TABLE ' || fqtn
|| ' ADD CONSTRAINT ' || quote_ident(cn)
|| ' CHECK (st_scale' || $4 || '('
|| quote_ident($3)
|| ')::numeric(16,10) = (' || attr || ')::numeric(16,10))';
RETURN _add_raster_constraint(cn, sql);
Executing this from psql I get the same error:
# select (1252219.04682188)::numeric(16,10);
ERROR: numeric field overflow
DETAIL: A field with precision 16, scale 10 must round to an absolute
value less than 10^6.
I think this is related to other issues people is having, not only because
of big values of ScaleX or ScaleY but also with very small values, when
input values have too much precision:
http://gis.stackexchange.com/questions/118120/numeric-issue-while-loading-
floating-point-valued-geotiff-into-postgis
http://gis.stackexchange.com/questions/59732/uploading-raster-format-tif-
to-postgis-through-raster2pgsql
I'll try to provide a simple means of reproducing this issue. As for the
patch, I think the input values must be rounded instead of adding a
constraint.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3005>
