[postgis-tickets] [PostGIS] #3004: Comments and extension files may not be installing
PostGIS trac at osgeo.org
Mon Dec 1 09:27:13 PST 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by robe):
 I can't replicate this issue on my mingw64 install when installing from
 tar ball.  I confirmed the 2.1.4 tarball already has the comments files
 built, so even if you don't have xsltproc installed, comments generation
 should not be an issue.  But something does seem a bit fishy at least on
 FreeBSD and CentOS.  Could be a difference in makes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3004#comment:1>
