[postgis-tickets] [PostGIS] #3006: Numeric overflow when executing AddRasterConstraints
PostGIS trac at osgeo.org
Mon Dec 1 09:47:53 PST 2014
 Reporter:  rtorre  |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  high    |   Milestone:  PostGIS 2.1.5
Component:  raster  |     Version:  2.1.x
 Keywords:          |
Comment(by robe):
 rtorre,
 I'll try to come with a better scale precision to use.  The reason swe
 don't use round is since the raster values are stored as numeric, round
 doesn;t work.
 So for example:
 SELECT round( (1252219.04682188555)::double precision,10);
 would give you an error of:
 ERROR:  function round(double precision, integer) does not exist
 So safest to just keep it as numeric cast and increase the casting scale
 and precision.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3006#comment:2>
