[postgis-tickets] [PostGIS] #3006: Numeric overflow when executing AddRasterConstraints
trac at osgeo.org
Wed Dec 3 09:22:40 PST 2014
Reporter: rtorre | Owner: dustymugs
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.5
Component: raster | Version: 2.1.x
Keywords: |
Comment(by robe):
rtorre -- thinking about this more I think your change while in principal
is fine is too much of a breaking change.
Talked with dustymugs on IRC and he was okay with just increasing the
precision to 25,10.
The issue with your change is that that check constraint is parsed out by
the function _raster_constraint_info_scale
So your proposed change would require us to rewrite to support that new
format as well as older constraint format. Since this is a critical
change that should go into 2.1.5, I don't feel comfortable doing such a
change that requires such extensive testing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3006#comment:8>
