[postgis-tickets] [PostGIS] #3004: Comments and extension files may not be installing
trac at osgeo.org
Thu Dec 4 13:17:15 PST 2014
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.5
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by pramsey):
I fooouund it! or something very much like it. I worked through a number
of vagrant installs and today was freebsd day, and this is what I found.
Here's my error
---- Making all in postgis
gmake[3]: Entering directory '/usr/home/vagrant/postgis-
svn/extensions/postgis'
mkdir -p sql
cat ../../postgis/postgis.sql ../../raster/rt_pg/rtpostgis.sql | /bin/sh
/usr/local/lib/postgresql/pgxs/src/makefiles/../../config/missing perl
../../utils/create_unpackaged.pl postgis > sql/postgis--unpackaged--
2.2.0dev.sql
cannot open
/usr/local/lib/postgresql/pgxs/src/makefiles/../../config/missing: No such
file or directory
Makefile:50: recipe for target 'sql/postgis--unpackaged--2.2.0dev.sql'
failed
gmake[3]: *** [sql/postgis--unpackaged--2.2.0dev.sql] Error 2
gmake[3]: *** Deleting file 'sql/postgis--unpackaged--2.2.0dev.sql'
I do have xsltproc installed, and a clean build will create the comments
in the doc directory. The problem is with PGXS, which is over-writing our
value of $(PERL) with it's own value, which is "/bin/sh
/usr/local/lib/postgresql/pgxs/src/makefiles/../../config/missing". Rather
than, say "/usr/bin/perl". This is the *second* hell nonsense I endured
during my platform playing thanks to PGXS, which makes using pre-built
postgresql packages really quite hard.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3004#comment:4>
