[postgis-tickets] [PostGIS] #2485: [raster]: raster constraints prevent raster data from restoring
trac at osgeo.org
Tue Dec 9 07:36:18 PST 2014
Reporter: rdunklau | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.7
Component: raster | Version: trunk
Keywords: |
Comment(by robe):
I have yet another hackish solution to this I came across by accident. If
you create a constraint as NOT VALID, it will check the constraint for
future inserts/updates to the table, but will not check existing data and
will also not check the constraint during load.
I still need to verify, but I think doing a
ALTER TABLE sometable
ADD CONSTRAINT enforce_num_bands_rast CHECK (st_numbands(rast) = 3) NOT
VALID;
might do the trick and maybe we can include that as a load option. it
would makeloading much faster too since it wouldn't have to validate on
load, but puts a bit of trust on user's understanding of their data.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:34>
