[postgis-tickets] [PostGIS] #3003: Will just not compile anymore on FreeBSD 10.1
trac at osgeo.org
Sat Dec 13 18:34:11 PST 2014
Reporter: martin5519 | Owner: pramsey
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.1.5
Component: postgis | Version: 2.1.x
Resolution: fixed | Keywords:
Changes (by martin5519):
* status: new => closed
* resolution: => fixed
Comment:
Ok, I ended up doing a fresh install on a 32-bit system (because I had the
chassis) of FreeBSD 9.3. I installed Postgres 9.3 and then installed
Postgis21. It went off without a hitch!
There was definitely an issue with either the upgrade from 9.1 to 10.1 or
an issue with 10.1 period. Anyways, I'm glad it's working now!!
Martin
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3003#comment:21>
