[postgis-tickets] [PostGIS] #3009: ST_Area(the_geom, false) may change column value
PostGIS trac at osgeo.org
Wed Dec 17 06:15:41 PST 2014
 Reporter:  fursten  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by robe):
 Same issue on my
 POSTGIS="2.2.0dev r13129" GEOS="3.5.0dev-CAPI-1.9.0 r4034" PROJ="Rel.
 4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24"
 LIBXML="2.7.8" LIBJSON="0.12" RASTER
 I think it IS changing data as improbable as that seems.  To test, I shut
 down my PostgreSQL service and restarted it and reran the ST_Astext and
 the same changed value showed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3009#comment:4>
