[postgis-tickets] [PostGIS] #3010: PostGis Topology performance improvements: edge_data indexes
trac at osgeo.org
Sat Dec 20 13:52:44 PST 2014
Reporter: bjornharrtell | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone:
Component: topology | Version: 2.1.x
Keywords: |
I've been following the effort to investigate and improve topology
performance.
I've used pg_stat_statements (with track all) to get statement statistics
when loading a dataset of 100000 polygons into a topology. I use
TopoGeo_AddPolygon and separate transactions for each area to avoid any
issues with a single long running transaction and as the significant time
spent is in TopoGeo_AddPolygon anyway.
In the resulting top list of statements with most time spent at third and
fourth place came the following statements which I found suspicious:
`UPDATE topo.edge_data SET next_right_edge = ?, abs_next_right_edge = ?
WHERE edge_id != ? AND next_right_edge = ?`
`UPDATE topo.edge_data SET next_left_edge = ?, abs_next_left_edge = ?
WHERE edge_id != ? AND next_left_edge = ?`
I noted that next_right_edge and next_left_edge are not indexed in
edge_data and conclude that these updates must be triggering sequential
scans of edge_data. Adding indexes results in a very significant
performance increase and from what I can tell a performance curve with
diminishing increases in time per object loaded.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3010>
