[postgis-tickets] [PostGIS] #2630: Typo in UpdateGeometrySRID parameter name
PostGIS trac at osgeo.org
Sun Feb 2 06:33:39 PST 2014
 Reporter:  strk     |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Changes (by robe):
  * milestone:  PostGIS 2.1.2 => PostGIS 2.2.0
Comment:
 I feel it's okay to drop in a minor release. I'm out to lunch in micro --
 it's borderline.  In most cases I wouldn't unless it was causing problems
 like ambiguous name conflict.
 no I will not name ST_, cause then I'd have to keep the old name anyway
 and also do the same with all the other management functions --
 http://postgis.net/docs/manual-dev/reference.html#Management_Functions
 Massive renamings should only be done in major releases in my opinion
 where people can expect some non-backward compatibility.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2630#comment:2>
