[postgis-tickets] [PostGIS] #2549: ST_Intersection throws error when ST_IsValid returns true
PostGIS trac at osgeo.org
Tue Feb 4 14:56:23 PST 2014
  Reporter:  nightdrift  |       Owner:  pramsey
      Type:  defect      |      Status:  closed
  Priority:  high        |   Milestone:  PostGIS 2.1.2
 Component:  postgis     |     Version:  2.1.x
Resolution:  wontfix     |    Keywords:
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Using your WKT representations (your WKB seem to be muddled) I do get
 validity errors
 postgis22=# select st_isvalid(g) from inter;
 NOTICE:  Ring Self-intersection at or near point 139.456321226
 -20.897800989
  st_isvalid
  t
  f
 probably your WKB don't have the errors, but the WKT errors are pointing
 up that the coordinates are a hair's breadth away from having them (and
 the slight rounding that the WKT caused is showing them up). Try a very
 very very fine snap to grid, followed by a call to makevalid. Might not
 work, but also might. Also consider some simplification and makevalid,
 since probably you aren't that concerned about an "exact" answer.
 This is yet another case where GEOS snap rounding would be nice to have.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2549#comment:1>
