[postgis-tickets] [PostGIS] #2634: regression failure ST_DWithin between 2.0.4 and 2.1.2
trac at osgeo.org
Tue Feb 4 15:13:15 PST 2014
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: postgis | Version: 2.1.x
Keywords: |
This is unwatered down fresh from garden bot. I'll try to water it down
to something we can throw in our tests:
This is running on:
POSTGIS="2.1.2dev r12220" GEOS="3.4.2-CAPI-1.8.2 r0" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER
SELECT ST_DWithin(geography(foo1.the_geom), geography(foo2.the_geom), 100,
false) As result,
ST_Distance(geography(foo1.the_geom), geography(foo2.the_geom)),
_ST_DistanceUncached(geography(foo1.the_geom), geography(foo2.the_geom) )
FROM ((SELECT ST_Collect(ST_SetSRID(ST_MakePoint(i,j,k),4326)) As the_geom
FROM generate_series(-10,50,20) As i CROSS JOIN generate_series(40,70, 25)
j CROSS JOIN generate_series(1,3) k )) As foo1
CROSS JOIN ((SELECT ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05) As
the_geom FROM (SELECT a*1.11111111 FROM generate_series(-10,50,10) As a)
As i(i) CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, i*j, j)) As
foo2 LIMIT 2;
result | st_distance | _st_distanceuncached
f | 229423.805745173 | 229423.805745173
f | 75661.624157771 | 0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2634>
