[postgis-tickets] [PostGIS] #2647: rtpostgis-2.1.dll invalid access to memory location
trac at osgeo.org
Fri Feb 21 13:15:47 PST 2014
Reporter: aikirhino | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.2
Component: build/upgrade/install | Version: 2.1.x
Keywords: rtpostgis-2.1 windows |
Comment(by robe):
forgot to say other things that I suspect may cause this
1) GDAL_DATA path not set (e.g. you said no to the set path question in
installer, or you hand set it yourself wrong)
2) Permission issue to the GDAL_DATA path
3) You copied over files while those files were in use so your copy did
not overwrite everything
4) You many need to restart your PostgreSQL service for new changes such
as gdal data path to take effect.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2647#comment:3>
