[postgis-tickets] [PostGIS] #2647: rtpostgis-2.1.dll invalid access to memory location
PostGIS trac at osgeo.org
Fri Feb 21 13:09:35 PST 2014
 Reporter:  aikirhino              |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  high                   |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:  rtpostgis-2.1 windows  |
Changes (by robe):
  * owner:  strk => robe
Comment:
 Which version are you using (2.1.1 ?) and which exact version of
 postgreSQL 9.3
 select version() , postgis_full_version();
 I've run into this problem once or twice on my windows 7 and was never
 able to recreate the issue.  Someone else complained and then when they
 restarted their service the issue went away.
 See related tickets #2460 , #2476
 You might also want to verify your gdal path location as I suspect that
 might be related if the path doesn't exist.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2647#comment:2>
