[postgis-tickets] [PostGIS] #2650: Can't compile with --enable-debug anymore
trac at osgeo.org
Sat Feb 22 19:31:56 PST 2014
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: postgis | Version: 2.1.x
Keywords: |
This might just be me, but in trying to test 2.1, I realized I can't
compile with --enable-debug anymore.
I deleted my 2.1 branch and repulled from svn to make sure it wasn't just
me messing with stuff
when compiling with
export XSLTPROCFLAGS=
CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-
libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
LDFLAGS="-L${PGPATH}/lib
-L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS
}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
--host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-
libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
--with-pgconfig=${PGPATH}/bin/pg_config \
--with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
--with-
geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin
/geos-config \
--with-projdir=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
--with-
gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin
/gdal-config \
--with-jsondir=${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}
--with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
--with-gui --with-gettext=no --enable-debug
I get this error:
make[1]: Entering directory `/projects/postgis/branches/2.1/postgis'
gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
statement -Wendif-labels -Wmissing-format-attribute -Wformat-security
-fno-strict-aliasing -fwrapv -fexcess-precision=standard -g
-I../liblwgeom -I../libpgcommon
-I/projects/geos/rel-3.5.0devw64gcc48/include -I/projects/proj/re
l-4.8.0w64gcc48/include -I/projects/libxml/rel-
libxml2-2.7.8w64gcc48/include/libxml2
-I/projects/postgresql/rel/pg9.3w64gcc48/include -I/projects/rel-
libiconv-1.13.1w64gcc48/include -fPIC -I. -I.
-Ic:/MING64~1/projects/POSTGR~1/rel/PG9~1.3W6/include/server
3W6/include/internal -I./src/include/port/win32 -DEXEC_BACKEND
"-Ic:/MING64~1/projects/POSTGR~1/rel/PG9~1.3W6/lib/pgxs/src/MAKEFI~1/../../src/include/port/win32"
-Ic:/MING64~1/projects/POSTGR~1/rel/PG9~1.3W6/include/server/port/win32
-c -o geography_measurement_trees.o geography_measurement_trees.
c
geography_measurement_trees.c:1:0: warning: -fPIC ignored for target (all
code is position independent) [enabled by default]
#include "geography_measurement_trees.h"
In file included from
c:/MING64~1/projects/POSTGR~1/rel/PG9~1.3W6/include/server/postgres.h:48:0,
from ../libpgcommon/lwgeom_cache.h:16,
from geography_measurement_trees.h:3,
from geography_measurement_trees.c:1:
geography_measurement_trees.c: In function 'CircTreePIP':
geography_measurement_trees.c:88:67: error: 'lwgeom2' undeclared (first
use in this function)
POSTGIS_DEBUGF(3, "tree1_type=%d, lwgeom2->type=%d", tree1_type,
lwgeom2->type);
c:/MING64~1/projects/POSTGR~1/rel/PG9~1.3W6/include/server/utils/elog.h:117:14:
note: in definition of macro 'ereport_domain'
errfinish rest; \
../libpgcommon/lwgeom_pg.h:42:25: note: in expansion of macro 'ereport'
ereport(NOTICE, (errmsg_internal("[%s:%s:%d] "
msg, __FILE__, __func__, __LINE__, __VA_ARGS__))); \
geography_measurement_trees.c:88:2: note: in expansion of macro
'POSTGIS_DEBUGF'
lwgeom2->type);
geography_measurement_trees.c:88:67: note: each undeclared identifier is
reported only once for each function it appears in
lwgeom2->type);
errfinish rest; \
'POSTGIS_DEBUGF'
lwgeom2->type);
<builtin>: recipe for target `geography_measurement_trees.o' failed
make[1]: *** [geography_measurement_trees.o] Error 1
make[1]: Leaving directory `/projects/postgis/branches/2.1/postgis'
GNUmakefile:14: recipe for target `all' failed
make: *** [all] Error 1
This used to work a while back when I was trying to poke at the geography
tree issues we were having
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2650>
