[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
PostGIS trac at osgeo.org
Sat Feb 22 20:19:05 PST 2014
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by robe):
 strk,
 Did you do anything with event trigger functions.  I noticed the same
 problem with those, that if I move my extension to postgis schema, they
 are still stuck in public.
 I confirmed this was not an issue before your change by upgrading from
 postgis 2.1.0 to postgis 2.1.1 (then moving to schema postgis).  In that
 case the trigger event functions moved along.  Trigger functions are
 chechauthtrigger()
 postgis_cache_bbox()
 I know that my logic for extension drops all functions from the extension
 package since the assumption is they will be recreated with CREATE OR
 REPLACE FUNCTION.  So this suggests the upgrade script is no longer
 including these trigger functions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560#comment:21>
