[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
trac at osgeo.org
Sun Feb 23 05:48:31 PST 2014
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: build/upgrade/install | Version: 2.1.x
Keywords: |
Comment(by strk):
I think you should not drop anything explicitly, except obsoleted
signatures (and ideally only those that have been obsoleted _exactly_ by
the currently being built version).
I haven't done anything (intentionally) with event triggers.
I'll try your testing. Sounds like something that could be automated as it
doesn't rely on any older version, right ? Do you think you could encode
it into a script ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560#comment:22>
