[postgis-tickets] [PostGIS] #2656: Bots are mad -- can't compile 2.2 chain
trac at osgeo.org
Tue Feb 25 06:20:40 PST 2014
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by robe):
nope
http://debbie.postgis.net:8080/job/PostGIS_Regress/3359/console
make[2]: Entering directory
`/var/lib/jenkins/workspace/postgis/branches/2.2/extensions/postgis_tiger_geocoder'
for OLD_VERSION in 2.0.0 2.0.1 2.0.2 2.0.3 2.0.4 2.1.0 2.1.1; do \
cat ../postgis_extension_helper.sql
sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql
sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql
../postgis_extension_helper_uninstall.sql >
sql/postgis_tiger_geocoder--$OLD_VERSION--2.2.0dev.sql; \
done
make[2]: Leaving directory
---- Making all in postgis_topology
`/var/lib/jenkins/workspace/postgis/branches/2.2/extensions/postgis_topology'
make[2]: *** No rule to make target
`../../topology/topology_upgrade_22_minor.sql', needed by
`sql/topology_upgrade_minor.sql'. Stop.
make[1]: *** [all] Error 1
make[1]: Leaving directory
`/var/lib/jenkins/workspace/postgis/branches/2.2/extensions'
make: *** [all] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2656#comment:5>
