[postgis-tickets] [PostGIS] #2629: [raster] Masks as POI lists
trac at osgeo.org
Fri Jan 31 23:09:23 PST 2014
Reporter: nclay | Owner: dustymugs
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Future
Component: raster | Version: trunk
Keywords: |
Mask internally to MapAlgebra should not be represented by 2D arrays as
that leads to an iteration over every element. When in the sparse case of
a mask it would be much more efficient to set the deterministic values
then iterate over the non-deterministic values and setting their
appropriate return value. Thus minimizing the number of iterations
MapAlgebra does for each mask operation.
mask = [
3.14,0,0,0,3.14
0,0,0,0,0
3.14,0,0,0,3.14
poi = [3,2]
poiList = [ [0,0,3.l4],[0,4,3.14],[2,0,3.14],[2,4,3.14]]
eg.
poilist = [[x,y,mValue],...,[poix,poiy,1]]
However, we must be careful not to detrimentally affect the execution of
dense masks. The code implementing this should take into account the
sparseness of an mask and take appropriate action.
eg. With a dense mask it would be best not to preset any of the values in
the returning array as this would just waist execution time. However with
a sparse mask the opposite is true. There for a separate utility function
should be created to encapsulate the logic of determining how best to
represent the mask as a poi list and the presetting of deterministic
values.
rt_util_mask_to_poi( .... )
Also it may be beneficial to a user to have the ability to hint MapAlgebra
that a mask is sparse through a optional hint in the Mask Object.
sparse = BOOLEAN
When NULL a best effort determination is made by:
rt_util_mask_to_poi( ... )
Also, this will require a new rt_pixel function as well as a new rt_mask
representation:
rt_pixel_set_poi_to_array( ... )
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2629>
