[postgis-tickets] [PostGIS] #2777: [raster] Huge literal in enforce_max_extent_rast check constraint (was: Huge literal in enforce_max_extent_rast check constraint)
trac at osgeo.org
Tue Jul 1 03:50:34 PDT 2014
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone:
Component: raster | Version: trunk
Keywords: |
Comment(by strk):
I'd keep the standard constraints for the sole purpose of enforcing what
raster_columns is advertising. If there's nothing in raster_columns that
depends on the "convex hull" of the raster, I'd rather avoid having it
constrained by the AddRasterConstraint function.
BTW, documentation for the function does not mention "extent" as being one
of the constraints:
http://postgis.net/docs/RT_AddRasterConstraints.html nor in the short or
in the detailed description. Was it a recent introduction ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2777#comment:9>
