[postgis-tickets] [PostGIS] #2798: raster2pgsql spins CPU on statement timeout
trac at osgeo.org
Tue Jul 1 10:12:47 PDT 2014
Reporter: strk | Owner: dustymugs
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS GDAL
Component: raster | Version: trunk
Resolution: | Keywords:
Comment(by rouault):
Sandro, there's no GDAL symbol in the above stacktrace. You should break
several times to have a representative sample, and it is expected that
sometimes it will show GDAL symbols. The performance might depend on if
the original TIFF is tiled or not, and how raster2pgsql uses the GDAL API.
But one hour is a lot.
Did you just try "gdal_translate timeseq_change00_12.tif out.tif -co
TILED=YES" ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2798#comment:9>
