[postgis-tickets] [PostGIS] #2807: [raster] ST_MapAlgebra injecting a default NODATA value of 0
trac at osgeo.org
Thu Jul 3 10:09:45 PDT 2014
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone:
Component: raster | Version: trunk
Keywords: |
Both the callback-based and the expression-based ST_MapAlgebra functions
are setting the NODATA flag in output and a nodata value of 0, even if the
input has no NODATA flag at all.
This is a quick test for the expression based version:
select (ST_BandMetadata(ST_MapAlgebra(ST_AddBand(ST_MakeEmptyRaster(2,
2,0,0,1.0),'8BUI',255.0), 1, '8BUI','0'))).nodatavalue;
And this is a quick test for the callback based version:
create function cb(float8[][][], int[][], text[]) returns float8 as
'select 1::float8' language 'sql';
'cb(float8[][][],int[][],text[])'::regprocedure))).nodatavalue;
I don't think a NODATA should be injected.
The documentation doesn't indeed mention anything about such enforcement.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2807>
