[postgis-tickets] [PostGIS] #2808: Installing newer topology than version of PostGIS gives misleading upgrade message
PostGIS trac at osgeo.org
Thu Jul 3 11:44:44 PDT 2014
message
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  low       |   Milestone:  PostGIS 2.2.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 Just had andre on IRC install postgis_topology 2.2.0dev
 and he gets this message
  TOPOLOGY (topology procs from "2.2.0dev r12721" need upgrade)
 when running
 SELECT postgis_full_version();
 The message is a bit misleading it says that if your version of TOPOLOGY
 doesn't match your version of PostGIS.  In this case he is running a newer
 TOPOLOGY and PostGIS 2.1.3.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2808>
