[postgis-tickets] [PostGIS] #2811: Do not specify an index name from shapefile and raster loaders
trac at osgeo.org
Fri Jul 4 10:09:24 PDT 2014
Reporter: strk | Owner: mcayland
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: loader/dumper | Version: trunk
Keywords: raster, shapefile |
Starting with PostgreSQL 9.0 (the minimum supported by PostGIS 2.2.0)
there's no need to specify an index name on CREATE INDEX:
http://www.postgresql.org/docs/9.0/interactive/sql-createindex.html
Omitting the name makes PostgreSQL choose a suitable name for you.
I was hit by forcing a name getting an exception after waiting for 40
minutes for an import. The explicitly mentioned name of that index was
already in use :/
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2811>
