[postgis-tickets] [PostGIS] #2777: [raster] Huge literal in enforce_max_extent_rast check constraint
trac at osgeo.org
Fri Jul 4 11:05:00 PDT 2014
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone:
Component: raster | Version: trunk
Keywords: |
Comment(by robe):
I don't think it's worth changing. In raster it can't have any number of
vertices, and I'm more concerned about breaking people's assumptions and
forcing them to rebuild all their indexes if we do this. And even though
the end seems like the same, to the planner it is not so it would never
use an existing index unless we require everyone to drop thier indexes and
reindex for 2.2.
I think originally a long time ago we use ST_Envelope, but the fundamental
difference bewteen the ST_Envelop and ST_ConvexHull is that ST_ConvexHull
handles rotated rasters and will give the right answer. So it saved a bit
in those functions calls where we know there is no nodata because those
type of functions would naturally use the index. If you change then they
have to do both an ST_Envelop and an ST_ConvexHull to utilize index.
Other issue before which I don't think is relevant now is that ST_envelope
was float4 rather than float4. I wish Pierre was here to explain. I
don't recall the long discussion of why this makde ST_Envelope kinda
useless.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2777#comment:17>
